Used when memory allocation is failed. %size%: the size of the memory allocated. %object%:Object
The system might be running with low memory. Reduce the load on the system. Reboot may be required
Error
malloc(%size%) failed %object%.
| Name | Type |
| size | uInt32 |
| object | String |
